[Proj] Detecting new lat, lon coordinates from a initial point with an angle and length
support.mn at elisanet.fi support.mn at elisanet.fi
Mon Dec 16 03:55:26 PST 2013
Hello,
well, that is exactly what the proj.4 is created for .. you just
read all the documentation etc. and you should be able
to do it!
http://trac.osgeo.org/proj/
There is no short cut ... except if you find some
open source code somewhere in the net ... which you
anyway have to usually modify.
Best luck! Janne.
SIVA RAMA KRISHNA [s.r.kriishna at gmail.com] kirjoitti:
> Hello,
> Thanks in advance
> I have a *lat, lon* coordinate with a known projection system I assume it a
> initial point. I want to generate a next Position with the an *angle* with
> (horizontal/vertical)  and *bearing length*  in lat,lon  coordinates and
> complete it with angles and bearing lengths to form a polygon
> Any Help in the above context is highly appreciated
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
