[Proj] (no subject)
Mon Dec 16 14:16:08 PST 2013
Siva,
I believe you want to use the "geod" program distributed with PROJ.4.  The
man page, possibly a bit out of date is at:
  http://trac.osgeo.org/proj/wiki/man_geod
Example use:
$ geod +ellps=WGS84
Input:
33 -117 15 10000
Output:
33d5'13.53"N 116d58'20.2"W -164d59'5.581"
So if you gave it an initial location of 33N 117W, an azimuth(bearing) of
15 degrees and a distance 10000m you would arrive at the output location
given with the third value being the azimuth back to the original point.
You should be able to construct what you want from this.
There is also a corresponding C API.
Best regards,
Frank
On Sun, Dec 15, 2013 at 10:56 PM, SIVA RAMA KRISHNA
<s.r.kriishna at gmail.com>wrote:
> Hello,
> Thanks in advance
> I have a *lat, lon* coordinate with a known projection system I assume it
> a initial point. I want to generate a next Position with the an
> *angle* with  (horizontal/vertical)  and *bearing length*  in lat,lon
> coordinates and complete it with angles and bearing lengths to form a
> polygon
> Any Help in the above context is highly appreciated
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20131216/93af871d/attachment.html>
