[Proj] EPSG codes for regional maps..
Mikael Rittri Mikael.Rittri at carmenta.com
Tue Feb 19 05:41:40 PST 2013
Carl Godkin wrote:
> EPSG codes provide a very concise representation
> For coordinate systems but I don't know how to
> look up EPSG-defined coordinate systems for large
> regional maps such as North America or Europe.
> Are there any?
Not as many as one would expect. And I don't know
any good way to search for them.
Apart from the ones already mentioned, here are a few:
EPSG:3572   "WGS 84 / North Pole LAEA Alaska"	Northern hemisphere - north of 45°N, including Arctic.
EPSG:3574   "WGS 84 / North Pole LAEA Atlantic"	Northern hemisphere - north of 45°N, including Arctic.
EPSG:3571   "WGS 84 / North Pole LAEA Bering Sea"	Northern hemisphere - north of 45°N, including Arctic.
EPSG:3573   "WGS 84 / North Pole LAEA Canada"	Northern hemisphere - north of 45°N, including Arctic.
EPSG:3575   "WGS 84 / North Pole LAEA Europe"	Northern hemisphere - north of 45°N, including Arctic.
EPSG:3576   "WGS 84 / North Pole LAEA Russia"	Northern hemisphere - north of 45°N, including Arctic.
EPSG:3832   "WGS 84 / PDC Mercator"		Pacific Ocean
EPSG:3973   "WGS 84 / NSIDC EASE-Grid North"	World - north of 0°N
EPSG:3974   "WGS 84 / NSIDC EASE-Grid South"	World - south of 0°N
EPSG:3975   "WGS 84 / NSIDC EASE-Grid Global"	World - 86°S to 86°N
EPSG:5041   "WGS 84 / UPS North (E,N)"		Northern hemisphere - north of 60°N onshore and offshore, including Arctic.
EPSG:5042   "WGS 84 / UPS South (E,N)"		Southern hemisphere - south of 60°S onshore and offshore - Antarctica.
If you can use ESRI codes as well, there are more to
choose from (some of these may exist in EPSG, too):
ESRI:102001   "Canada_Albers_Equal_Area_Conic"
ESRI:102002   "Canada_Lambert_Conformal_Conic"
ESRI:102003   "USA_Contiguous_Albers_Equal_Area_Conic"
ESRI:102004   "USA_Contiguous_Lambert_Conformal_Conic"
ESRI:102005   "USA_Contiguous_Equidistant_Conic"
ESRI:102008   "North_America_Albers_Equal_Area_Conic"
ESRI:102009   "North_America_Lambert_Conformal_Conic"
ESRI:102010   "North_America_Equidistant_Conic"
ESRI:102011   "Africa_Sinusoidal"
ESRI:102012   "Asia_Lambert_Conformal_Conic"
ESRI:102013   "Europe_Albers_Equal_Area_Conic"
ESRI:102014   "Europe_Lambert_Conformal_Conic"
ESRI:102015   "South_America_Lambert_Conformal_Conic"
ESRI:102016   "North_Pole_Azimuthal_Equidistant"
ESRI:102017   "North_Pole_Lambert_Azimuthal_Equal_Area"
ESRI:102018   "North_Pole_Stereographic"
ESRI:102019   "South_Pole_Azimuthal_Equidistant"
ESRI:102020   "South_Pole_Lambert_Azimuthal_Equal_Area"
ESRI:102021   "South_Pole_Stereographic"
ESRI:102022   "Africa_Albers_Equal_Area_Conic"
ESRI:102023   "Africa_Equidistant_Conic"
ESRI:102024   "Africa_Lambert_Conformal_Conic"
ESRI:102025   "Asia_North_Albers_Equal_Area_Conic"
ESRI:102026   "Asia_North_Equidistant_Conic"
ESRI:102027   "Asia_North_Lambert_Conformal_Conic"
ESRI:102028   "Asia_South_Albers_Equal_Area_Conic"
ESRI:102029   "Asia_South_Equidistant_Conic"
ESRI:102030   "Asia_South_Lambert_Conformal_Conic"
ESRI:102031   "Europe_Equidistant_Conic"
ESRI:102032   "South_America_Equidistant_Conic"
ESRI:102033   "South_America_Albers_Equal_Area_Conic"
ESRI:102034   "North_Pole_Gnomonic"
ESRI:102035   "North_Pole_Orthographic"
ESRI:102036   "South_Pole_Gnomonic"
ESRI:102037   "South_Pole_Orthographic"
You can find the definitions at http://help.arcgis.com/en/arcims/10.0/mainhelp/mergedProjects/ArcXMLGuide/elements/pcs.htm
(And the ESRI codes 53001 to 54053 give various world maps.)
A map projection for Russia can be found here http://nsidc.org/data/docs/fgdc/ggd601_russia_soil_maps/index.html
I don't know if it has any official status. If it is important to keep north up,
one would instead use some Mercator with central meridian in the middle of Russia.
Best regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
