[Proj] coordinates in decimal degrees and Albers Equal Conic projection
Swagath Navin swagathnavin82 at gmail.com
Mon Mar 11 05:46:28 PDT 2013
Dear all,
Sorry for being naive, i am completely new to map projections. I have a
data set with coordinates in decimal degrees (-14.36, 53.23) with the
following information:
"The coordinates are designed to be used at the scale of the European
continent (Albers Equal Area Conic projection, with the following
projection settings: Scale = 1; False Easting(m) = 5000000; False
Northing(m) = 0; Longitude Origin = 20; Latitude Origin = 0; Standard
Parallel 1 = 45; Standard Parallel 2 = 55, and the Ellipsoid is WGS 84)"
i would like to know if the coordinates are already in WGS84 or is there
any conversion required.
Thanks a lot for your time and help.
Navin
