[Proj] cs2cs syntax help
nicolas david ericnico.david at gmail.com
Tue Oct 15 00:06:36 PDT 2013
Re
sorry send my previous message before ending
so you have to tranform your cs2cs command from
cs2cs +proj=latlong +datum=WGS84 +to  +proj=utm +zone=51 +datum=WGS84 -r
to
cs2cs +proj=latlong +datum=WGS84 +to  +proj=utm +zone=51 +south
+datum=WGS84 -r
or using epsg dictionnary
cs2cs +init="EPSG:4326" +to  +init="EPSG:32751" -r
Nicolas DAVID
2013/10/15 nicolas david <ericnico.david at gmail.com>
> Hi Szilard
> concerning you first point "using the command properly"
> a) first you have to use input telling if your coordinate are north/south
> and east/west. so transform
> 26d25'55" 126d15'04"  to 26d25'55"S 126d15'04"E
> b) you need to specifie that you want UTM51 south and not utm51 north by
> using the +south parameters
> spatialreference.org is a very good ressource for finding this kind of
> stuff : http://www.spatialreference.org/ref/epsg/32751/
> 2013/10/15 Szilard Albert <szilard.albert at gmail.com>
>> Dear list,
>> very new to this, I have a question that might be very easily answered by
>> someone familiar with cs2cs.
>> I have the following Lat/Lon coordinates pair (few thousand pairs
>> actually)
>> 262555.03S 1261004.91E
>> 261455.02S 1261504.90E
>> 265555.04S 1261404.93E
>> with datum/spheroid/etc description as below. Zone 51, Australia.
>> H1400 GEODETIC DATUM SURVEYED   WGS84       WGS84        6378137.000
>> 298.2572229
>> H1401 TRANSFORMATION PARAMETERS    0.0   0.0   0.0 0.000 0.000 0.000
>> 0.0000000
>> H1500 GEODETIC DATUM AS PLOTTED WGS84       WGS84        6378137.000
>> 298.2572229
>> H1501 TRANSFORMATION PARAMETERS    0.0   0.0   0.0 0.000 0.000 0.000
>> 0.0000000
>> H1600 DATUM SHIFTS                 0.0   0.0   0.0 0.000 0.000 0.000
>> 0.0000000
>> H1700 VERTICAL DATUM            N/A
>> H1800 PROJECTION                GEODETIC
>> H1900 ZONE                      N/A
>> H2002 ANGULAR UNITS             1    DEGREES
>> H2100 STANDARD PARALLELS          0 0 0.000N  0 0 0.000N
>> H2200 CENTRAL MERIDIAN            0 0 0.000E
>> H2301 GRID ORIGIN                 0 0 0.000N  0 0 0.000E
>> H2302 GRID COORDINATES AT ORIGIN       0.00W       0.00S
>> I need to transform these to XY coordinates.
>> Using
>> <<EOF
>> EOF
>> I get
>> 824270.31       2927618.51 0.00
>> X looks OK, but for the Y values I am expecting values around 6,9xx,xxx ~
>> 7,0xx,xxx
>> Would you please:
>> 1. Point me towards using the command properly
>> 2. Suggest best format of my text file for batch conversion. Can easily
>> manipulate/separate columns, would prefer not to have to inset d, ', "
>> symbols, but would be able if necessary.
>> Thanks for your help,
>> regards,
>> Szilard
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20131015/62f882ac/attachment.html>
