[Proj] Projection bounds question
    Richard Greenwood
    richard.greenwood at gmail.com
    Thu Oct 24 08:57:26 PDT 2013
Coordinate systems do not generally have defined bounds although there may
be laws that govern where a given coordinate system is to be used. In
theory, you could represent any place on the earth in any coordinate system.
Regarding UTM, a given coordinate pair would be valid in any of the 60 UTM
zones since false x and y are the same in every zone. Only the longitude
origin changes between zones.
I don't know if this would be helpful in your case, but an interesting tool
that was introduced at FOSS4G-NA this year can help make educated guesses
about coordinate systems: http://projfinder.com/
Rich
On Thu, Oct 24, 2013 at 3:11 AM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Hi,
> Is there a way to find out the bounds of a given projection?
> Let’s say I have a given projection (UTM) and have a point (supposedly in
> the same utm) but I want to find out if that point is within the bounds of
> the projection.
> Let me know if you have ideas.
> Best regards,
> Tamas
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Richard Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20131024/780d4b1b/attachment.html>
More information about the Proj
