[Proj] Projection bounds question
Carl Godkin cgodkin at gmail.com
Thu Oct 24 09:31:19 PDT 2013
Hi Tamas,
If you have questions about the bounds for a specific coordinate system,
and know its EPSG code, you can use the EPSG registry to look up its "Area
of Use."
Hope that helps,
carl
On Thu, Oct 24, 2013 at 2:11 AM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Hi,
> Is there a way to find out the bounds of a given projection?
> Let’s say I have a given projection (UTM) and have a point (supposedly in
> the same utm) but I want to find out if that point is within the bounds of
> the projection.
> Let me know if you have ideas.
> Best regards,
> Tamas
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20131024/1612245b/attachment.html>
