[Proj] #229 - trunk init still broken
Even Rouault even.rouault at spatialys.com
Tue Aug 19 05:13:31 PDT 2014
Could someone with admin rights in Trac close the 4.8.0 target ?
I've reviewed a few tickets this morning, including the 2 ones identified as
"critical", closing one by adding remaining tests
(http://trac.osgeo.org/proj/ticket/219) and defering the other one for "later"
since it is not particularly new and can be workarounded by adding custom
towgs84 parameters (http://trac.osgeo.org/proj/ticket/241)
If people want specific tickets to go in 4.9.0, I'd suggest them to raise their
criticity and assign 4.9.0 target. We are not going to fix all open remaining
tickets... I think "critical" here means regressions w.r.t previous releases,
compilation issues, ...
"make check" runs OK (except with testntv2 where there are some minor
differences in decimal values, perhaps due to using an updated ntv2_0.gsb grib
?), so we shouldn't be too far from being able to release.
Even
> On Tue, Aug 19, 2014 at 9:05 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> > On Tue, 19 Aug 2014, Howard Butler wrote:
> >> I'd be happy to champion a release cycle, but I don't feel I'm the one
> >> to go through the bug list and prioritize things.
> > There are 28 in trunk and 46 in unspecified, so this isn't trivial. All
> > are owned by Frank (reasonably enough). How might we move forward on this?
> It might be worthwhile to assign "Milestones" to each (or at least the
> important) ticket:
> http://trac.osgeo.org/proj/report/1
> ... in order to get a better picture here:
> http://trac.osgeo.org/proj/roadmap
> Markus
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
http://www.spatialys.com
