[Proj] Mapserver Projection Issue
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jan 2 06:43:29 PST 2014
On 1/2/2014 9:13 AM, Richard Greenwood wrote:
> Are you sure that it's finding and using the correct epsg file? You
> could specify the full path to an epsg file in either the mapfile or the
> apache conf, or paste the proj parameters into the PROJ block in the
> mapfile and do away wit the epsg file completely.
It is a clean new system with only the Ubuntu package installed. I added
900913 to the /usr/share/proj/epsg file. I also just modified the
mapfile and entered the projection parameters in it directly as you
suggested with the same result.
If you want to try this, download http://imaptools.com:8080/dl/world.tbz
It resides in directory /u/data/ on my system so you would need to
adjust the paths appropriately.
I've now spent 3 days fussing with this and trying to debug it. I
suppose the next thing to try is to build proj4-4.6.0 on the Ubuntu
system and see if that resolves the issue.
Thanks,
   -Steve
Here is the mapfile:
MAP
   NAME "World_WMS"
   STATUS ON
   SIZE 800 800
   #EXTENT -180 -90 180 90
   EXTENT -20037508.34 -20037508.34  20037508.34  20037508.34
   UNITS DD
   SHAPEPATH "/u/data/world/"
   IMAGECOLOR "#80B1D3"
   FONTSET "/u/data/world/fontset.txt"
   IMAGETYPE "agg_qn"
   MAXSIZE 4000
   CONFIG MS_ERRORFILE "stderr"
   CONFIG ON_MISSING_DATA "IGNORE"
   #DEBUG 10
   OUTPUTFORMAT
     NAME "agg_qn"
     DRIVER "AGG/PNG"
     EXTENSION "png"
     MIMETYPE "image/png"
     IMAGEMODE RGB
     FORMATOPTION "INTERLACE=false"
     FORMATOPTION "QUANTIZE_NEW=ON"
     FORMATOPTION "QUANTIZE_FORCE=ON"
     FORMATOPTION "QUANTIZE_DITHER=OFF"
     FORMATOPTION "QUANTIZE_COLORS=256"
   END
   OUTPUTFORMAT
     NAME aggpng24
     DRIVER AGG/PNG
     IMAGEMODE RGB
     EXTENSION "png"
   END
   WEB
     METADATA
       "labelcache_map_edge_buffer" "-20"
       "ows_title" "World_WMS"
       "ows_onlineresource"
"http://imaptools.com:8080/cgi-bin/mapserv?map=/u/data/world/world.map&"
       "ows_srs" "EPSG:4326 EPSG:900913 EPSG:4269 EPSG:3857"
       "ows_feature_info_mime_type" "text/html"
       "ows_enable_request" "GetMap"
       "ows_contactperson"     "Stephen Woodbridge"
       "ows_contactorganization" "iMaptools.com"
       "ows_contactposition"   "Owner"
       "ows_contactelectronicmailaddress" "info at imaptools.com"
       "ows_attribution_title"   "Data copyright by LeadDog Consulting."
     END
   END
#  PROJECTION "init=epsg:4326" END
   PROJECTION "+proj=lcc +lat_1=17.5 +lat_2=29.5 +lat_0=12 +lon_0=-102
+x_0=2500000 +y_0=0 +datum=WGS84 +units=m +no_defs" END
   LAYER
     STATUS DEFAULT
     TYPE POLYGON
     FEATURE
         POINTS -180 -90 -180 90 180 90 180 -90 -180 -90 END
     END
     CLASS
       STYLE
         COLOR "#80B1D3"
       END
     END
   END
   LAYER
     NAME "World"
     GROUP "cb"
     METADATA
       ows_title "World"
       ows_group_title "Land Mass"
     END
     STATUS ON
     TYPE POLYGON
     DATA "world_dissolve"
     CLASS
       STYLE
         COLOR "#CACACA"
         OUTLINECOLOR "#888888"
       END
     END
   END
END
> Rich
> On Wed, Jan 1, 2014 at 9:47 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Hi All,
>     I'm trying to run down a mapserver projection issue that is starting to
>     look like it might be the version of proj4. Sorry for the cross posting.
>     Situation:
>     I'm upgrading my server from Debian Lenny to Ubuntu 12.04 LTS and world
>     maps on the Ubuntu system projected to Spherical Mercator are messed up
>     and worked fine on Debian. I get the same issue using mapserver 6.2.1 or
>     5.6.8 and the big difference other than the OS and packages is that
>     Ubuntu is using proj4-4.8.0 and the older Debian system is using
>     proj4-4.6.0
>     Is this a known issue? I can make the data mapfile available if that
>     helps.
>     System details below.
>     Any help would be appreciated.
>     Thanks,
>         -Steve
>     Ubuntu system:
>     http://imaptools.com:8080/cgi-bin/mapserv?MAP=%2Fu%2Fdata%2Fworld%2Fworld.map&FORMAT=image%2Fpng&LAYERS=World_WMS&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-27395030.9325,-21524667.16125,27395030.9325,21524667.16125&WIDTH=700&HEIGHT=550
>     /u/www/cgi-bin/mapserv -v
>     MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
>     SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>     SUPPORTS=SVG_SYMBOLS SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
>     SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>     SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
>     SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
>     INPUT=GDAL INPUT=SHAPEFILE
>     libproj-dev/precise uptodate 4.8.0-3~precise2
>     libproj0/precise uptodate 4.8.0-3~precise2
>     proj-bin/precise uptodate 4.8.0-3~precise2
>     proj-data/precise uptodate 4.8.0-3~precise2
>     # Spherical Mercator projection
>     <900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
>     +x_0=0.0 +y_0=0 +k=1.0 +units=m +over +nadgrids=@null +no_defs  <>
>     cgi-mapserver/precise uptodate 6.2.1-2~precise3
>     libmapserver/precise uptodate 6.2.1-2~precise3
>     mapserver-bin/precise uptodate 6.2.1-2~precise3
>     Linux mappy 3.8.0-33-generic #48~precise1-Ubuntu SMP Thu Oct 24 16:28:06
>     UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
>     I also get the same result from:
>     /u/www/cgi-bin/mapserv-56 -v
>     MapServer version 5.6.8 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>     OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
>     SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>     SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>     INPUT=SHAPEFILE
>     which was built from source also using the libproj packages above.
>     Debian Lenny system:
>     http://gis.imaptools.com/cgi-bin/mapserv-6.2?MAP=%2Fu%2Fdata%2Fworld%2Fworld.map&FORMAT=image%2Fpng&LAYERS=World_WMS&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-27395030.9325,-21524667.16125,27395030.9325,21524667.16125&WIDTH=700&HEIGHT=550
>     proj/lenny uptodate 4.6.0-2
>     # Spherical Mercator - Google
>     Linux gis.leaddog.com <http://gis.leaddog.com> 2.6.32-042stab081.8
>     #1 SMP Wed Oct 23 16:32:28 MSK
>     2013 x86_64 GNU/Linux
>     I built mapserver from source and I also get the same result from
>     mapserver-5.6.8 built from source.
>     _______________________________________________
>     Proj mailing list
>     Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>
>     http://lists.maptools.org/mailman/listinfo/proj
> Richard Greenwood
> richard.greenwood at gmail.com <mailto:richard.greenwood at gmail.com>
> www.greenwoodmap.com <http://www.greenwoodmap.com>
> Proj mailing list
