[Proj] Parsing Lambert Conformal Conic in GDAL
    Kyle Shannon
    kyle at pobox.com
    Thu Jan  2 19:00:23 PST 2014
I've come across a proj.4 projection (lcc) that may not be parsed
correctly by GDAL/OGR.  If I roundtrip EPSG:3979 through gdalsrsinfo,
I lose a standard parallel (forgive the clutter):
kyle at kyle-hp-laptop:gdal$ gdalsrsinfo -o proj4 EPSG:3979
'+proj=lcc +lat_1=49 +lat_2=77 +lat_0=49 +lon_0=-95 +x_0=0 +y_0=0
+ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs '
kyle at kyle-hp-laptop:gdal$ gdalsrsinfo -o wkt '+proj=lcc +lat_1=49
+lat_2=77 +lat_0=49 +lon_0=-95 +x_0=0 +y_0=0 +ellps=GRS80
PROJCS["unnamed",GEOGCS["GRS 1980(IUGG,
1980)",DATUM["unknown",SPHEROID["GRS80",6378137,298.257222101],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic_1SP"],PARAMETER["latitude_of_origin",49],PARAMETER["central_meridian",-95],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1]]
So, is:
a completely valid proj.4 string?  Is it okay to set a lat_1=lat_0,
and also specify lat_2.  I suspect it is, but I haven't found any
concrete definition on limits (and I don't really think there are,
within reason).
Thought I'd consult the pros on the list to be sure.
There is a ticket on gdal trac at: http://trac.osgeo.org/gdal/ticket/5191
Thanks.
Kyle
More information about the Proj
