[Proj] puzzled with +towgs84=... being ignored
Andre Joost andre+joost at nurfuerspam.de
Thu Jan 9 20:55:05 PST 2014
Am 10.01.2014 01:28, schrieb J. Luis:
> I'm very lost with this results where setting the +towgs84 is ignored
> unless I set "+datum=WGS84"
> Why so? and why is the source "+ellps=WGS84" ignored as well?
This is the usual behaviour: +towgs84 is only used when a datum shift is
defined on both sides (from and to), either by specifying
+datum=...
+nadgrids=...
+towgs84=...
HTH,
Andre Joost
