[Proj] Info on proj4 formulas
support.mn at elisanet.fi support.mn at elisanet.fi
Fri May 9 06:43:34 PDT 2014
Hello,
the exact formulas are in the source code..
the source code is the definition and
formula..
Regards: Janne.
Andrea Peri [aperi2007 at gmail.com] kirjoitti:
> Hi Jeff,
> I just this morning search in the
> OF90-284.pdf
> but nothing found about the formulas.
> I search better in other sections of documentation.
> A.
> 2014-05-08 19:38 GMT+02:00 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
> > Hi Andrea,
> > Have you reviewed the "Documentation" section of
> > http://trac.osgeo.org/proj/ ?
> > -jeff
> > Jeff McKenna
> > MapServer Consulting and Training Services
> > http://www.gatewaygeomatics.com/
> > On 2014-05-08, 2:27 PM, Andrea Peri wrote:
> > > Hi,
> > > I'm just now subscribe to this MialingLIst so before all
> > > My best wish to all the readers.
> > > I'm searching info about what formula is use in the proj4 to reproiect
> > data.
> > > There is a document where is describe the used formulas. ?
> > > I need to understand how far is the proj4 results from other tools used
> > > in Italy
> > > AFAIK in Italy is used a formula usually know as the "Formula's
> > Bonifacino".
> > > Thx,
> > > Andrea Peri
> > > qwerty àèìòù
> > Proj mailing list
> > Proj at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/proj
> Andrea Peri
> qwerty àèìòù
> Proj mailing list
