[Proj] Info on proj4 formulas
Norman Vine nhv at cape.com
Fri May 9 07:19:47 PDT 2014
On May 9, 2014, at 10:05 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> You have right.
> I can read and try to understand the code but i don't know the PROJ lib.  There is a specific file source dedicate to the reprojection functions ?
Each projection has its own file these are named  "PJ_XXXX"
where XXXX is an abbreviation of the projection's name
Proj4 is the codification of Snyder's "Map Projections: A Working Manual"
Where the derivation of the projections are discussed
this is available as a pdf from
http://pubs.er.usgs.gov/publication/pp1395
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20140509/c70b9937/attachment.html>
