[Proj] Info on proj4 formulas
Finn, Michael mfinn at usgs.gov
Fri May 9 09:16:00 PDT 2014
Thanks for posting this!
On Fri, May 9, 2014 at 8:31 AM, Nick Ves <vesnikos at gmail.com> wrote:
> Intresting,
> But now I'm wondering if the OGP's "Geomatics Guidance Note Number 7,
> part 2 Coordinate Conversions and Transformations including Formulas"
> [0] has been taken into account in the realizations of the formulas.
> [0] http://www.ogp.org.uk/pubs/373-07-2.pdf
> On Fri, May 9, 2014 at 5:19 PM, Norman Vine <nhv at cape.com> wrote:
> > On May 9, 2014, at 10:05 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
> > Hi,
> > You have right.
> > I can read and try to understand the code but i don't know the PROJ lib.
> > There is a specific file source dedicate to the reprojection functions ?
> > Each projection has its own file these are named  "PJ_XXXX"
> > where XXXX is an abbreviation of the projection's name
> > Proj4 is the codification of Snyder's "Map Projections: A Working Manual"
> > Where the derivation of the projections are discussed
> > this is available as a pdf from
> > http://pubs.er.usgs.gov/publication/pp1395
> > Proj mailing list
> > Proj at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20140509/e4f6993c/attachment.html>
