[Proj] Converting to WGS84 Latitude/Longitude
Artur Bercik vbubbly21 at gmail.com
Fri Oct 24 03:47:41 PDT 2014
On Fri, Oct 24, 2014 at 7:30 PM, Charles Clercq <charles.clercq at gmail.com>
wrote:
> Dear all,
> I found a pdf document:
> http://www.yale.edu/ceo/Documentation/MODIS_data.pdf
> which state: "The data are provided in the HDF-EOS format. MODIS data at
> version 4 and above use
> the Sinusoidal projection with the WGS84 datum. A very small sample of
> common
> products are listed below."
> Hope it helps
Thank you Charles. However, the statement you have found is for land
products, and I am using atmospheric products. In this case, the data are
provided in geographic coordinate system. The pair of lats and lons I have
read are in geographic coordinate system, but do not know the datum.
> 2014-10-24 9:30 GMT+02:00 Artur Bercik <vbubbly21 at gmail.com>:
>> On Fri, Oct 24, 2014 at 3:50 PM, Mikael Rittri <
>> Mikael.Rittri at carmenta.com> wrote:
>>>   Hi Artur.
>>> It could be the same thing. “Geodetic” latitude is the same as ordinary,
>>> everyday latitude. There are some other flavours of latitude as well,
>>> auxiliary latitudes that are mainly used to simplify some kinds of
>>> computations, but “geodetic” is the ordinary kind.
>>> For longitudes, there is only one flavour, but the zero meridian is
>>> not always Greenwich.
>>> So the coordinates you mention could be in WGS84 Lat/Long already.
>>> But it is not certain, since they could be expressed in some other
>>> geodetic datum that uses a different ellipsoid.
>>> Do you have any documentation about the geodetic datum of your
>>> coordinates (like Pulkovo 1942, Pulkovo 1995, PZ 1990, or WGS84),
>>> or about the ellipsoid used?
>> Dear Mikael Rittri
>> Thanks for your answer.
>> Actually, I could not understand which datum or ellepsoid was used. The
>> following documents says only geodetic latitude and longitude:
>> http://modaps.nascom.nasa.gov/services/about/products/MOD03.html
>> I have read the above data product; and retrieved the pairs of geodetic
>> lats and lons as the document says, but could not figure out if  I should
>> convert them into WGS84 or not. I have to compare the data using above
>> product with other data which are in WGS84 lats and lons.
>>> Best regards,
>>> Mikael Rittri
>>> Carmenta
>>> Sweden
>>> http://www.carmenta.com
>>> *From:* proj-bounces at lists.maptools.org [mailto:
>>> proj-bounces at lists.maptools.org] *On Behalf Of *Artur Bercik
>>> *Sent:* Friday, October 24, 2014 8:27 AM
>>> *To:* proj at lists.maptools.org
>>> *Subject:* [Proj] (no subject)
>>> Dear Proj list members:
>>> Being a very new in this field, could someone answer me about the
>>> following problem:
>>> I have a pair of Geodetic Latitude and Geodetic Longitude (50.89524,
>>> 117.69043).
>>> How can I convert it into Latitude and Longitude with WGS84 Ellepsoid?
>>> Thanks in the advance.
>>> Artur
>>> Proj mailing list
>>> Proj at lists.maptools.org
>>> http://lists.maptools.org/mailman/listinfo/proj
>> Proj mailing list
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20141024/00dd7a68/attachment.html>
