[Proj] Problem about egm96 geoid hight calculation
Yutaka KURASHINA Kurashina.Yutaka at mss.co.jp
Wed Sep 10 23:01:02 PDT 2014
Dear all,
I use proj.4(4.8.0) and egm96 geoid data below.
   http://download.osgeo.org/proj/vdatum/egm96_15/egm96_15.gtx
     Last modified 15-Feb-2014 08:15
I'm trying to calculate egm96 geoid height with cs2cs.
But I could not get the height at boundary of the geoid data.
At first I ran a command below.
$ cs2cs +proj=latlong +geoidgrids=./egm96_15.gtx +to +proj=latlong <<EOF
heredoc> 0 0 0
heredoc> EOF
0dE     0dN 17.162
This works well. But, the next command didn't.
heredoc>     0  90 0
heredoc>     0 -90 0
heredoc>   180   0 0
heredoc>  -180   0 0
heredoc> EOF
Rel. 4.8.0, 6 March 2012
<cs2cs>: while processing file: <stdin>, line 1
pj_transform(): point not within available datum shift grids
*       * 0.000
<cs2cs>: while processing file: <stdin>, line 2
*       * 0.000
<cs2cs>: while processing file: <stdin>, line 3
*       * 0.000
<cs2cs>: while processing file: <stdin>, line 4
*       * 0.000
Is there anything wrong in the commands?
I would like to ask for advice.
Thank you in advance.
Yutaka Kurashina
