[Proj] ACT Standard Grid (AGD66)
Michel.Dastous at bentley.com Michel.Dastous at bentley.com
Tue Apr 14 09:54:43 PDT 2015
Thank you all, after reverting the rotation values everything is fine!
Michel
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Andre Joost
Sent: Monday, April 13, 2015 11:52 PM
To: proj at lists.maptools.org
Subject: Re: [Proj] ACT Standard Grid (AGD66)
Am 14.04.2015 um 02:18 schrieb Richard Greenwood:
> On Mon, Apr 13, 2015 at 11:39 AM, Hermann Peifer <peifer at gmx.eu> wrote:
>> so you should use
>> +towgs84=-129.19,-41.21,130.73,.25,.37,.33,-2.96
> If you reverse the sign then shouldn't it be:
> +towgs84=129.19,41.21,-130.73,-.25,-.37,-.33,2.96
> or am I missing what you are suggesting?
Only the rotations have to be reversed. The first three are shifts, and the last one is a scale factor. These remain unchanged.
HTH,
André Joost
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
