[Proj] degree to radian conversions
Charles Karney charles.karney at sri.com
Thu Aug 13 13:46:03 PDT 2015
I just submitted a pull request for proj.4 to correct the values of the
constants used in degree/radian conversions.  The important change was
to use
   .0174532925199432958
instead of
   .0174532925199433
as the value of pi/180 used to convert degrees to radians in dmstor.c.
The new value is substantial closer to the true value...
   cos(90 * .0174532925199432958) =  6.1e-17
   cos(90 * .0174532925199433)    = -3.8e-16
Needless to say, some of the tests now fail.  Particularly because
proj.4 used to round 90 deg to an illegal latitude (larger than pi/2).
However the changes for the healpix checks are inexplicably large.
It would be good if someone could figure out why the healpix results
change so much.
   --Charles
