[Proj] 4.9.1RC1 Released
Thomas Knudsen knudsen.thomas at gmail.com
Sat Feb 21 09:47:28 PST 2015
I have not been following proj development closely for the last years, but
I think it would be appropriate to add a few more names to the AUTHORS file:
To the "Contributors section":
Charles Karney (for, if I remember correctly, a major rewrite of the
geodesics code, and a large number of high quality patches)
Karsten Engsager and Knud Poder (for the "Engsager Extended Transverse
Mercator" code in proj_etmerc.c)
To the "Maintainers" section:
Howard Butler (apparently the new, or at least the current, maintainer :-) )
I'm probably missing some?
/Thomas
2015-02-21 17:37 GMT+01:00 Howard Butler <howard at hobu.co>:
> > On Feb 21, 2015, at 9:19 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Me neither. For folks looking, here's the state of things :
> > $ find ../install-proj-4.9.1-autoconf/lib/
> > ../install-proj-4.9.1-autoconf/lib/libproj.so.9
> > ../install-proj-4.9.1-autoconf/lib/libproj.a
> > ../install-proj-4.9.1-autoconf/lib/pkgconfig
> > ../install-proj-4.9.1-autoconf/lib/pkgconfig/proj.pc
> > ../install-proj-4.9.1-autoconf/lib/libproj.la
> > ../install-proj-4.9.1-autoconf/lib/libproj.so.9.0.0
> > $ find ../install-proj-4.9.1-cmake/lib/
> > ../install-proj-4.9.1-cmake/lib/libproj.so.4.9.1
> > ../install-proj-4.9.1-cmake/lib/libproj.so.9.0.0
> > And for reference:
> > $ find ../install-proj-4.8.0/lib  (autoconf build)
> > ../install-proj-4.8.0/lib/libproj.a
> > ../install-proj-4.8.0/lib/libproj.so.0.7.0
> > ../install-proj-4.8.0/lib/pkgconfig
> > ../install-proj-4.8.0/lib/pkgconfig/proj.pc
> > ../install-proj-4.8.0/lib/libproj.la
> Fix attempted at https://trac.osgeo.org/proj/ticket/263
> The CMake configuration was using VERSION target properties which is
> probably not what we want.
> Howard
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150221/8decc316/attachment.html>
