[Proj] Proj 4.9.1RC3 Released
Charles Karney charles.karney at sri.com
Sat Feb 21 16:10:18 PST 2015
On 02/21/2015 04:31 PM, Howard Butler wrote:
>> On Feb 21, 2015, at 1:59 PM, Charles Karney <charles.karney at sri.com> wrote:
>> This patch adds 3 files in the cmake directory.  The names need to be
>> added to EXTRA_DIST in cmake/Makefile.am, of course.  The files are
>> CMakeLists.txt project-config.cmake.in project-config-version.cmake.in
> Was there a specific reason this patch puts back the project VERSION target properties that I removed in r2969 [1]?
> https://trac.osgeo.org/proj/changeset/2629/trunk/proj
> We didn't want this due to it creating SOVERSION and file version names that are misaligned with what the libtool stuff does.
> Howard
I'm explicitly trying to mimic the behavior of libtool here using the 2
versions that cmake offers.  Here's what the so libraries look like:
   autoconf
     lrwxrwxrwx.  libproj.so -> libproj.so.9.0.0
     lrwxrwxrwx.  libproj.so.9 -> libproj.so.9.0.0
     -rwxr-xr-x.  libproj.so.9.0.0
   cmake (before my patch)
   cmake (with my patch)
There's some benefit in trying to keep the shared libraries consistent
between builds so that an executable can reliably find the necessary
shared libraries at runtime.
How do I know what numbers to put for the versions in CMakeLists.txt?  I
run the autoconf build and look at the resulting versions on the
installed libraries.
Incidentally, if I build an application linking against proj using
cmake, the shared library it looks for (after the patch) is
libproj.so.9.  This means that a later API-compatible version with bug
fixes can be installed as
     lrwxrwxrwx.  libproj.so.9 -> libproj.so.9.0.1
     -rwxr-xr-x.  libproj.so.9.0.1
and the application automatically will switch to the new version.
However this isn't a big deal, and I can back out of this change if you
like.
   --Charles
