[Proj] Proj 4.9.1RC3 Released
Greg Troxel gdt at ir.bbn.com
Sun Feb 22 16:52:17 PST 2015
Thanks for pushing out 4.9.1RC3.  I am the maintainer for the proj entry
in pkgsrc, a multi-OS packaging system.
4.9.1RC3 works fine (with the nit that it unpacks to proj-4.9.1 without
the RC3).  However, make check has a failure, which looks like overly
aggressive asumptions about floating point math.  This is on netbsd-6
i386, and I don't remember if that uses extended doubles or not.
=> Bootstrap dependency digest>=20010302: found digest-20121220
===> Testing for proj-4.9.1RC3
Making check in src
gmake[1]: Entering directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/src'
gmake[1]: Leaving directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/src'
Making check in man
gmake[1]: Entering directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/man'
Making check in man1
gmake[2]: Entering directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/man/man1'
gmake[2]: Nothing to be done for 'check'.
gmake[2]: Leaving directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/man/man1'
Making check in man3
gmake[2]: Entering directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/man/man3'
gmake[2]: Leaving directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/man/man3'
gmake[2]: Entering directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/man'
gmake[2]: Nothing to be done for 'check-am'.
gmake[2]: Leaving directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/man'
gmake[1]: Leaving directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/man'
Making check in nad
gmake[1]: Entering directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/nad'
/usr/pkg/bin/gmake  check-local
gmake[2]: Entering directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/nad'
../nad/test27 ../src/proj
Running ../nad/test27 using ../src/proj:
doing tests into file proj_out27, please wait
diff proj_out27 with pj_out27.dist
TEST OK
test file proj_out27 removed
../nad/test83 ../src/proj
Running ../nad/test83 using ../src/proj:
doing tests into file proj_out83, please wait
diff proj_out83 with pj_out83.dist
TEST OK
test file proj_out83 removed
PROJ_LIB=. ../nad/testvarious ../src/cs2cs
Running ../nad/testvarious using ../src/cs2cs:
doing tests into file tv_out, please wait
Rel. 4.9.1, 17 February 2015
<cs2cs>: while processing file: <stdin>, line 1
pj_transform(): invalid x or y
<cs2cs>: while processing file: <stdin>, line 2
pj_transform(): acos/asin: |arg| >1.+1e-14
diff tv_out with tv_out.dist
294c294
< 16.33 48.20	595710.37321015039925	5357598.46457545924932 -44.49510847218335
> 16.33 48.20	595710.37321015028283	5357598.46457545924932 -44.49510847218335
313c313
< 13 -10	2073986.9490880956873	-1680858.2722242793534 0.0000000000000
> 13 -10	2073986.9490880956873	-1680858.2722242795862 0.0000000000000
PROBLEMS HAVE OCCURED
test file tv_out saved
Makefile:541: recipe for target 'check-local' failed
gmake[2]: *** [check-local] Error 100
gmake[2]: Leaving directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/nad'
Makefile:386: recipe for target 'check-am' failed
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory '/u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj/work/proj-4.9.1/nad'
Makefile:428: recipe for target 'check-recursive' failed
gmake: *** [check-recursive] Error 1
*** Error code 2
Stop.
make: stopped in /u0/n0/gdt/NetBSD-current/pkgsrc/geography/proj
*** Error code 1
Stop.
make: stopped in /usr/pkgsrc/geography/proj
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150222/bdaf955e/attachment.sig>
