[Proj] Proj 4.9.1RC3 Released
Greg Troxel gdt at ir.bbn.com
Sun Feb 22 16:52:56 PST 2015
Here's a patch to the README to explain about tests.  This has been in
pkgsrc for several years.
$NetBSD: patch-README,v 1.1 2012/03/14 23:36:06 gdt Exp $
Sent upstream by email 20120309.
--- README.orig	2010-12-05 16:06:32.000000000 +0000
+++ README
@@ -40,6 +40,13 @@ After executing configure, execute:
 The install target will create, if necessary, all required sub-directories.
+To test, execute:
+	make check
+Note that you must have installed proj-datumgrid-1.5 in nad prior to
+building; the test suite includes grid shift tests.
 Windows Build
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20150222/e7c116b4/attachment.sig>
