[Proj] Proj 4.9.1RC3 Released
Sebastiaan Couwenberg sebastic at xs4all.nl
Mon Feb 23 06:04:11 PST 2015
>> On Feb 23, 2015, at 12:46 AM, Sebastiaan Couwenberg <sebastic at xs4all.nl>
>> wrote:
>> On 02/23/2015 01:52 AM, Greg Troxel wrote:
>>> 4.9.1RC3 works fine (with the nit that it unpacks to proj-4.9.1
>>> without the RC3).  However, make check has a failure, which looks
>>> like overly aggressive asumptions about floating point math.  This
>>> is on netbsd-6 i386, and I don't remember if that uses extended
>>> doubles or not.
>> Those three tests fail on more architectures, see:
>> https://trac.osgeo.org/proj/ticket/255
> I propose we dial back the precision on the test as Frank suggested.
That's probably the best short term solution, yes.
Kind Regards,
Bas
