[Proj] ticket #274: proj_def.dat left out of 4.9.1 tarball
Roger Bivand Roger.Bivand at nhh.no
Tue May 19 23:56:37 PDT 2015
http://trac.osgeo.org/proj/ticket/274
describes a puzzle we have seen with different behaviour wrt. errno -13.
The resolution is to reinstate proj_def.dat in /nad (and installed
PROJ_LIB). The Debian binary 4.9.1-1 was put on our testing servers a day
or so ago, causing considerable upsets in user R code omitting +ellps=.
The omission is visible in proj-data:
https://packages.debian.org/stretch/all/proj-data/filelist
compared to:
https://packages.debian.org/jessie/amd64/proj-data/filelist
Is a 4.9.2 release likely? This is quite a serious problem in that the
behaviour of PROJ.4 has changed at the user level from 4.8.0 to 4.9.1,
unless the system admin only overwrote PROJ_LIB without deleting it and
re-creating.
Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
