[Proj] Proj.4 4.9.2 RC2 Released
Even Rouault even.rouault at spatialys.com
Thu Sep 10 10:46:23 PDT 2015
Le jeudi 10 septembre 2015 19:36:51, Devrim Gündüz a écrit :
> Hi,
> Another API breakage then? :( Life is hard for packagers nowadays...
What to say... We could also have pretended there was no backward incompatible
change. This change is for a semi-public/semi-private symbol that is very
likely not used by any external code.
> Regards, Devrim
> On September 10, 2015 6:30:33 PM GMT+02:00, Howard Butler <howard at hobu.co>
wrote:
> >All,
> >Proj.4 4.9.2 RC2 is now available for testing. Please download it from
> >http://download.osgeo.org/proj/proj-4.9.2RC2.tar.gz (md5 at
> >http://download.osgeo.org/proj/proj-4.9.2RC2.tar.gz.md5)
> >http://download.osgeo.org/proj/proj-4.9.2RC2.zip (md5 at
> >http://download.osgeo.org/proj/proj-4.9.2RC2.zip.md5)
> >It includes fixes for three identified issues.
> >> 2015-09-10 sisyphus <https://github.com/sisyphus>
> >> 	* : Rename PVALUE in pj_param.cto prevent Windows variable name
> >clash
> >> 2015-09-10 Bas Couwenberg <https://github.com/sebastic>
> >> 	* : Don't include files in proj dist, also included in
> >proj-datumgrids
> >> 	dist #301
> >> 2015-09-10 Ture Pålsson <https://github.com/turepalsson>
> >> 	* : PTHREAD_MUTEX_RECURSIVE detection issue on FreeBSD #303
> >> 2015-09-10 Martin Raspaud <https://github.com/mraspaud>
> >> 	* : Don't return values when doing inverse projections outside of
> >the
> >> 	mollweide map #304
> >SOVERSION has been incremented to 10:0:0 in recognition of PVALUE
> >change. Should no more critical issues be identified, I will motion to
> >MetaCRS to make this release final tomorrow.
> >Howard
> >_______________________________________________
> >Proj mailing list
> >Proj at lists.maptools.org
> >http://lists.maptools.org/mailman/listinfo/proj
http://www.spatialys.com
