[Proj] Compiling the new 4.9.2 return a 4.9.1
Sebastiaan Couwenberg sebastic at xs4all.nl
Sun Sep 20 03:13:39 PDT 2015
On 20-09-15 12:03, Andrea Peri wrote:
> I download the new proj 4.9.2 yesterday and after compile and install
> it on a debian system ,
> I see the library are named
> libproj  (link)
> libproj.so.9 (link)
> libproj.so.9.1.0  (file)
> the last file "libproj.so.9.1.0" is right name ?
It is. The version in the library real name is not the release version.
libtool determines the library version using its -version-info option,
proj-4.9.2 uses -version-info 10:0:1 which results in library version
9.2.0 and SONAME libproj.so.9 (SOVERSION 9). See:
https://www.gnu.org/software/libtool/manual/html_node/Libtool-versioning.html
https://www.gnu.org/software/libtool/manual/html_node/Updating-version-info.html
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
