[Proj] Introducing some intrusive (but API neutral) code changes in PROJ.4
Richard Greenwood richard.greenwood at gmail.com
Mon Apr 4 11:33:08 PDT 2016
Sounds worthy to me. I just wish you had done it 10 years ago!
Rich
On Mon, Apr 4, 2016 at 12:21 PM, Thomas Knudsen <knudsen.thomas at gmail.com>
wrote:
> Hello proj users
> I have recently submitted a pull request for PROJ.4, introducing some
> rather intrusive code changes which will (hopefully) make a large part of
> the PROJ.4 code easier to read, maintain, and contribute to.
> Basically, the pull request will eliminate a large proportion of the
> somewhat convoluted macros that currently enforces the implementation
> policy for the projection code in PROJ.4. It should, however, not introduce
> any changes API-wise, so most users of the library, and the proj, cs2cs,
> and nad2nad programs should be unaffected.
> If you suspect your use case may be affected anyway (or if you may be in a
> position to offer helpful comments), please take a look at the pull request
> over at https://github.com/OSGeo/proj.4/pull/373
> Thomas Knudsen
> Geodesist, PhD
> thokn at sdfe.dk
> Danish Ministry of Energy, Utilities and Climate
> Agency for Data Supply and Efficiency
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20160404/a468f469/attachment.html>
