[Proj] Failing to correctly configure, compile and run Proj locally
Dr Rainer Woitok rainer.woitok at gmail.com
Tue Aug 9 05:04:05 PDT 2016
Greetings,
having recently cloned Proj from the Git repository at
   https://github.com/OSGeo/proj.4.git
I want to configure, compile, and use it only locally in my home direct-
ory.  For that I run the commands:
   $ export PREFIX=$HOME PROD=proj
   $ cmake -D CMAKE_BUILD_TYPE=RelWithDebInfo  \
           -D CMAKE_COLOR_MAKEFILE=OFF         \
           -D CMAKE_EXPORT_COMPILE_COMMANDS=ON \
           -D CMAKE_INSTALL_PREFIX="$PREFIX"   \
           -D CMAKE_LEGACY_CYGWIN_WIN32=0      \
           -D CONVERT_DATA=ON                  \
           -D DATADIR="$PREFIX/share/$PROD"    \
           -D DOCDIR="$PREFIX/doc/$PROD"       \
           -D INCLUDEDIR="$PREFIX/include"     \
           -D LIBDIR="$PREFIX/lib"             \
           -D MANDIR="$PREFIX/man"             \
           -D PROJ_BIN_SUBDIR=bin              \
           -D PROJ_DATA_SUBDIR="share/$PROD"   \
           -D PROJ_DOC_SUBDIR="doc/$PROD"      \
           -D PROJ_INCLUDE_SUBDIR=include      \
           -D PROJ_LIB_SUBDIR=lib              \
           -LAH ..
   $ cmake --build . --target all --target install
Apart from plenty of warnings regarding the redefinition of the constant
"M_TWOPI", the compilation succeeds.  However, the resulting "proj" bin-
ary refuses to run  as long as  environment variable "PROJ_LIB" does not
explicitly hold the path to "share/proj/":
$ env|grep PROJ
$ proj +init=epsg:32661
Rel. 4.9.3, dd Month yyyy
<proj>:
projection initialization failure
cause: no system list, errno: 2
program abnormally terminated
$ export PROJ_LIB=$HOME/share/proj
^D
Is there a way to  configure Proj in such a way  that it's not necessary
to correctly set environment variable "PROJ_LIB" at runtime?
Any pointers welcome :-)
Sincerely,
  Rainer
