[Proj] Question on +czech option
vanadovv at hetnet.nl vanadovv at hetnet.nl
Thu Aug 11 10:47:19 PDT 2016
The Original Krovak projection from 1922 has south-west axes, some years ago they changed to north-east.
So says the EPSG Guidance Note 7-1 (IOGP Publication 373-7-2 – Geomatics Guidance Note number 7, part 2) in the Krovak chapter.
Oscar van Vlijmen
>----Origineel Bericht----
>Van : mkennedy2 at earthlink.net
>Datum : 11/08/2016 01:48
>Aan : proj at lists.maptools.org
>Onderwerp : [Proj] Question on +czech option
>I am wondering if the parameter/option +czech is working correctly.
>If anyone is unfamiliar with it, this option is used with +proj=krovak, the Krovak projection used in former Czechoslovakia (and current Czech Republic).
>The 'native' Krovak has positive south, west axes (given in that order according to EPSG). Many Czech users are happy to use east, north axes in order to use various software packages that don't support multiple axis directions.
>Using an input point of latitude = 50, longitude = 20, I got these results (point is a little nonsensical due to using Ferro prime meridian in the tests):
>with czech (2065)
>cs2cs +to +proj=krovak +ellps=bessel +pm=ferro +x_0=0.0 +y_0=0.0
>          +lon_0=42d30'E +lat_0=49d30'N +k_0=0.9999 +czech +no_defs
>   cs2cs - PJ lib: 1589829.67     864777.51
>   forward 2065  :  864777.51    1589829.67 (Esri projection engine)
>without czech (5211)
>          +lon_0=42d30'E +lat_0=49d30'N +k_0=0.9999 +no_defs
>   cs2cs - PJ lib: -1589829.67   -864777.51
>   forward 5211  : -1589829.67   -864777.51 (Esri projection engine)
>So without the +czech option, we get east, north axes. With +czech, we get values in west, south axes order, rather than south, west. Is this correct behavior?
>Disclosure: I work at Esri and I'm on the subcommittee that maintains the EPSG Geodetic Registry.
>Melita
>Melita Kennedy
>Esri Sr. Product Engineer
>_______________________________________________
>Proj mailing list
>Proj at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/proj
