[Proj] Proj 4.9.3RC1 Released
Greg Troxel gdt at ir.bbn.com
Tue Aug 16 06:24:38 PDT 2016
Howard Butler <howard at hobu.co> writes:
> I have prepared a proj.4 4.9.3 RC1. At the moment it is simply a release cut from master. We still need to do the following:
> 1) Upgrade to EPSG 8.9 db
> 2) Prepare release notes
> 3) In/out decisions on existing PRs [1]
> You can download it at http://download.osgeo.org/proj/proj-4.9.3RC1.tar.gz and http://download.osgeo.org/proj/proj-4.9.3RC1.tar.gz.md5
Thanks for publishing an early RC.  I'll be happy to test future RCs,
e.g. another after db update and merging of various PRs.
I locally upgraded the pkgsrc package, and it built and passed the
included-with-proj tests on NetBSD 7 amd64.  Also postgis 2.2.2, when
built against the RC, passes its own tests.
I also built under pkgsrc on OS X 10.9 (and hence with clang) and that
tested ok.
Note that pkgsrc is still using the 1.5 grids, partly becuase we have a
policy of sticking to releases unless doing so is really broken, and
partly because I wasn't aware of the 1.6 RC.
There is a stray patch in the package:
$NetBSD: patch-README,v 1.2 2015/09/13 23:22:23 gdt Exp $
Sent upstream by email 20120309.
--- README.orig	2015-09-08 15:17:17.000000000 +0000
+++ README
@@ -40,6 +40,13 @@ After executing configure, execute:
 The install target will create, if necessary, all required sub-directories.
+To test, execute:
+	make check
+Note that you must have installed proj-datumgrid-1.5 in nad prior to
+building; the test suite includes grid shift tests.
 Windows Build
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20160816/a25109eb/attachment.sig>
