[Proj] Proj 4.9.3RC2 Released
Even Rouault even.rouault at spatialys.com
Wed Aug 17 05:30:24 PDT 2016
Le mercredi 17 août 2016 05:06:34, Howard Butler a écrit :
> All,
> proj.4 4.9.3 RC2 is now available [1]. It includes removal of the OSX cruft
> (I'm now using an Ubuntu container to generate the release), the EPSG data
> was updated to 8.9 (no substantive changes), and the distribution
> additions that Charles mentioned. Release notes and existing Pull Request
> decisions are yet to be done.
Howard,
regarding the EPSG 8.9 upgrade, it seems from
https://github.com/OSGeo/proj.4/commit/b2d1648195d5a2e3ea07015a7a60ee7ee04337b9
there was an issue with the regeneration of the proj 'epsg' file from the
updated csv files pcs.csv, etc... with the new Kyrgyzstan SRS.
For example there's the following line in 'epsg':
# Unknown
# Unable to translate coordinate system EPSG:7686 into PROJ.4 format.
But with GDAL updated:
$ gdalsrsinfo EPSG:7686
PROJ.4 : '+proj=longlat +ellps=GRS80 +no_defs '
OGC WKT :
GEOGCS["Kyrg-06",
    DATUM["Kyrgyzstan_Geodetic_Datum_2006",
        SPHEROID["GRS 1980",6378137,298.257222101,
            AUTHORITY["EPSG","7019"]],
        AUTHORITY["EPSG","1160"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9122"]],
    AUTHORITY["EPSG","7686"]]
So the definition in 'epsg' should be '+proj=longlat +ellps=GRS80 +no_defs '
I've actually manually run epsg_tr.py on gcs.csv and I do get the expected:
# Kyrg-06
<7686> +proj=longlat +ellps=GRS80 +no_defs  <>
So it seems that for some reason epsg_tr.py in your process found the 7686
entry in gcs.csv but wasn't able to resolve it as WKT / ExportToProj4.
Same for
# Unknown
+# Unable to translate coordinate system EPSG:7692 into PROJ.4 format.
$ gdalsrsinfo EPSG:7692
PROJ.4 : '+proj=tmerc +lat_0=0 +lon_0=68.51666666666667 +k=1 +x_0=1300000
+y_0=14743.5 +ellps=GRS80 +units=m +no_defs '
OGC WKT :
PROJCS["Kyrg-06 / zone 1",
    GEOGCS["Kyrg-06",
        AUTHORITY["EPSG","7686"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",68.51666666666667],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",1300000],
    PARAMETER["false_northing",14743.5],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
    AUTHORITY["EPSG","7692"]]
Regarding the libgeotiff update, the updated pcs.csv, gcs.csv, etc... files have
not been committed into SVN.
Even
http://www.spatialys.com
