[Proj] Proj 4.9.3RC2 Released
Even Rouault even.rouault at spatialys.com
Wed Aug 17 07:38:03 PDT 2016
> > #366 -- Fix +wgs84 parameters for 3844 (Romania) --
> > https://github.com/OSGeo/proj.4/pull/366 MERGE
As implemented currently it is a manual override of epsg, so it will be lost
at the next EPSG upgrade. A cleaner solution with the current infrastructure
would be to add the appropriate override in
https://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/pcs.override.csv and
resync GDAL, proj with it.
http://www.spatialys.com
