[Proj] Proj 4.9.3RC2 Released
Howard Butler howard at hobu.co
Thu Aug 18 07:45:53 PDT 2016
Charles,
I made a pass through the code to attempt to clean up the issues you've identified:
https://github.com/OSGeo/proj.4/pull/402
Howard
> On Aug 18, 2016, at 9:12 AM, Charles Karney <charles.karney at sri.com> wrote:
> proj 4.9.3RC2 is compiling successfully on our build machines.  Thanks!
> There was some discussion of normalizing whitespace a few weeks back and
> it was agreed not to do any blanket conversions from tabs to spaces in
> source code.
> However, with 4.9.3RC2, I note that some other whitespace irregularities
> have crept into the repository.  I recommend that these be corrected
> before release.
>   DOS line endings:
>     src/PJ_eck5.c
>     src/PJ_eck4.c
>     src/PJ_goode.c
>     src/PJ_eck1.c
>     src/PJ_isea.c
>     src/PJ_fahey.c
>     src/PJ_hatano.c
>     src/PJ_vandg4.c
>   Internal ^M
>     src/PJ_eck1.c
>   Trailing whitespace
>     man/man1/cs2cs.1
>     src/pj_factors.c
>     src/pj_gridinfo.c
>   Spaces followed by tabs
>     src/PJ_aitoff.c
>   Extra newlines at end of file
>     src/pj_list.c
>     src/pj_list.h
> Of these, the only really objectionable ones are the DOS line endings
> and the internal ^Ms.
> Now might also be a good time to eliminate all such irregularites at
> least within the C source code.  I might add to this list of candidates
> for fixing:
>   No newline at end of file
>   Internal tabs within a line
> On 08/16/16 23:06, Howard Butler wrote:
>> All,
>> proj.4 4.9.3 RC2 is now available [1]. It includes removal of the OSX cruft (I'm now using an Ubuntu container to generate the release), the EPSG data was updated to 8.9 (no substantive changes), and the distribution additions that Charles mentioned. Release notes and existing Pull Request decisions are yet to be done.
>> Additionally, I created a Dockerfile [2] that describes the process I used to generate the EPSG database updates. It produces the data for libgeotiff, proj.4, GDAL, and PostGIS if access to the ESRI FileGDB SDK is available before building the container.  I will also use the same container for generating releases (based on Ubuntu Xenial) unless someone chimes in with a reason why we shouldn't use that.
>> [1] http://download.osgeo.org/proj/proj-4.9.3RC2.tar.gz and http://download.osgeo.org/proj/proj-4.9.3RC2.tar.gz.md5
>> [2] https://gist.github.com/hobu/f27b1e06a45a2200bf7262a664d5b825
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
> SRI International, Princeton, NJ 08543-5300
> Tel: +1 609 734 2312
> Fax: +1 609 734 2662
> Proj mailing list
