[Proj] HARN nadgrid files
Even Rouault even.rouault at spatialys.com
Thu Dec 22 13:00:27 PST 2016
On jeudi 22 décembre 2016 13:40:23 CET Richard Greenwood wrote:
> I've been following a few of the recent threads on this list regarding
> enhancements to Proj's datum transformations. Pretty exciting stuff!
> One group of transformations that seems to have been ignored for a number
> of years is applying the HARN hpgn grids in the Proj epsg file. For example
> the Proj epsg entry for epsg:3758 uses +towgs84=0,0,0,0,0,0,0 but I believe
> that is should use +nadgrids=wyhpgn.gsb, or at least that's what I change
> it to, which produces results that match NADCON.
> Is anyone aware of a reason that nadgrids are not referenced in the epsg
> file? Is it maybe just an oversight, something that nobody ever got around
> to? Or because distributing nadgrids would become burdensome?
Richard,
I don't think we would want to force people using grids to be able to use EPSG codes
(because of the required space or licensing terms), but we could generate +nadgrids=@bla
syntax to make them optional. What could be useful is to have both +nadgrids= and
+towgs84 with the priority given to the grids when they are present but this isn't
implemented right now in proj.4 (if you have both +nadgrids and +towgs84, I believe
+nadgrids is always used, even if the grids are missing on the system)
As far as adding the grid info, in the current workflow, this would be a matter of doing that in
the https://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/build_pcs.py script,
presumably adding a new column in the gcs.csv file, and some logic/dictionary to match the
datum name with a grid name, and then updating GDAL to use that new information when
reading the .csv files.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20161222/b4862f1b/attachment.html>
