[Proj] Transformation pipelines - your opinion?
Thomas Knudsen knudsen.thomas at gmail.com
Sat Jun 4 20:46:08 PDT 2016
All,
I have recently opened a new pull request over at
https://github.com/OSGeo/proj.4/pull/388 ...
It introduces projection pipelines (i.e. multi-step transformations),
and, at the end-user facing side of things, a new 3D transformation
program called “tran”, which directly supports transformation
pipelines.
While the pull request expands the capabilities of proj.4
dramatically, the code is not very intrusive: Technically, the
pipeline driver is just a new projection, and hence a transformation
pipeline is introduced with the incantation “+proj=pipeline”.
I agree that at first, this may seem a bit odd, so I hope to initiate
a discussion here about e.g. the syntax, and aboult potentially useful
pipeline primitives: The code is still in its infancy, so a lot will
happen before it is ready for merging into the proj.4 master branch
(although I hope it can be done in time for version 4.10)
You can contribute to the discussion here and/or over at the github
page already mentioned. Also, you can read more about syntactic
details at my proj.4 page http://thomasknudsen.net/proj4.html, where
you can also find instructions for downloading a recent Windows build
of the “tran” tool.
/thomas
