[Proj] Github issue clean up
Kristian Evers kreve at sdfe.dk
Thu Oct 20 02:29:57 PDT 2016
All,
The last few days I have been going through all the reported issues on github [0]. That includes tickets from the old trac site that has been migrated to github. I wanted to close all tickets that are no longer valid. I ended up closing around 30 tickets that were either fixed, not applicable any more or if it seemed like no one cared about the issue. Along the way I have taken care of some of the more simple issues, mostly known bugs with a patch attached to the ticket.
Please have a look at the list of recently closed issues [1] and see if I inadvertently have closed an issue you still care about. That is very likely, especially for the old trac tickets. Let me know if that is the case and I will reopen the issue!
I would also like to ask you to go have a look at the list of known bugs [2] and see if you can help resolve some of the problems. Either by bringing more knowledge to the table or, even better, with a pull request that fixes the problem.
Thanks,
Kristian
[0] https://github.com/OSGeo/proj.4/issues
[1] https://github.com/OSGeo/proj.4/issues?q=is%3Aissue+is%3Aclosed+sort%3Aupdated-desc
[2] https://github.com/OSGeo/proj.4/issues?q=is%3Aissue+sort%3Aupdated-desc+is%3Aopen+label%3Abug
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20161020/9b7880fa/attachment.html>
