[Proj] proj-datumgrid git repository
Sebastiaan Couwenberg sebastic at xs4all.nl
Sat Oct 29 08:31:01 PDT 2016
On 10/29/2016 04:10 PM, Sebastiaan Couwenberg wrote:
> Unfortunately the resulting grid shift files are not identical to the
> ones included in proj-datumgrid-1.6. I haven't been able to figure out
> what causes that difference, the .lla sources may have changed for 1.6
> or it may just be some system dependent metadata (timestamp?), or
> something else entirely. I need to investigate this more thoroughly.
The reason for the non-identical grid shift files is that the nad2bin
output was not reproducible prior to PROJ.4 4.9.3, see:
 https://github.com/OSGeo/proj.4/pull/381
The ID is now zero padded instead of containing random data, and the ID
field is the only difference between the grid shift files in
proj-datumgrids-1.6 and those created from the .lla files included in
1.5 and earlier. See for example the diff for the hexdumps of the null
datum grid.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
Type: text/x-diff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20161029/4cee2235/attachment.diff>
