[Proj] Coming releases of PROJ.4
Kristian Evers kreve at sdfe.dk
Thu Jun 22 10:57:20 PDT 2017
Even,
> As far as I know in the FOSS ecosystem, projects.h use is very marginal, or accidental. The only occurence I've in mind is in the OGDI project that uses nad_init() in one place. But I wouldn't mind too much about OGDI...
Good, that makes it a bit easier. There might be users outside of FOSS and I think it is fair to give them some time to bring their things in order if/when we break stuff.
> I'm not completely sure but I think the main driver for the context system was to remove / deprecate use of pj_errno as a global error variable. errno is now attached to the context.
Yeah, I believe the idea was to make it thread-safe. Why regular errno is not used I can understand though.
> We should probably make sure it is in a clean enough way before releasing it to the world
I agree. I think we have time to get it in a reasonable state before august.
> I'm wondering: is there a reason for having a new proj.h ?
The idea was to produce a new clean API with more sensible types, better namespace, etc. It has been discussed earlier both here and on GitHub (for instance here https://github.com/OSGeo/proj.4/pull/388)
 > On the other hand, having the new header and removing the old one will be an obvious way of signaling "eh, breaking changes have occured !" :-)
That was exactly what I had in mind! Along with a giant leap forward in version number it should raise all the flags of people using PROJ.4.
It was also why I suggested to keep a maintenance version based on 4.9.4 for a few years. So developers have time to absorb the changes in their own time.
> Actually one of the point of having a dedicatd proj.h would be to make sure that people don't accidentally use old API that will be removed. But I see that proj.h includes proj_api.h, so this risk still exists. Why proj.h couldn't avoid the proj_api.h depedency ?
I think it should be possible to remove the dependency of proj_api.h in proj.h. Perhaps by putting the parts that are dependant on proj_api.h in a proj_internal.h as suggested in your GitHub issue?
Kristian
Fra: Even Rouault [mailto:even.rouault at spatialys.com]
Sendt: 22. juni 2017 18:48
Til: proj at lists.maptools.org
Cc: Kristian Evers
Emne: Re: [Proj] Coming releases of PROJ.4
Kristian,
> The projects.h interface has a long history and exposes
> most of the inner workings of PROJ.4.
> That is also why the
> proj_api.h interface exists. It was created in an effort of simplifying
> things and making a more modern API. That was now roughly 15 years ago, and
> On top of that it has some unfortunate
> design choices, for instance the context-system which is rather hard to
> work with and comprehend. Unfortunately it is also completely undocumented
> and the original ideas behind it seem to be lost.
While just reviewing proj.h, I had a few questions/observations :
https://github.com/OSGeo/proj.4/issues/529 (I see you've began to answer to some questions while I was still editing it ;-))
> PROJ.4 also has three different build-systems: Autotools, nmake and CMake.
> Autotools is the authoritative build-system which the other two try to
> mimic as best as possible. Nmake was introduced in order to build PROJ.4 on
> Windows and lately CMake has also been introduced as there was a demand for
> it.
> Due to the above I suggest that we focus our efforts entirely on the proj.h
> API and CMake from the next release and onwards.
Adoption of the new API and deprecation of proj_api.h will show greater resistance than dropping autoconf/nmake.
I'm wondering: is there a reason for having a new proj.h ? (we perhaps discussed that, but I already forgot) Imagine that I want to write code that is compatible of old and new proj versions (I'm pretty sure that a number of proj users will have to do that at some point). It could be convenient to still include proj_api.h and depending on the value of PJ_VERSION decide which API are available. Whereas if you have a new header, that make you also change your autoconf/cmake logic detection of proj4.
In the transition period, proj_api.h could have two sections : a section with the new API and with the ancient API clearly separated. At some point ancient API would be removed.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170622/42a00a9e/attachment.html>
