[Proj] Coming releases of PROJ.4
Sebastiaan Couwenberg sebastic at xs4all.nl
Fri Jun 23 00:18:53 PDT 2017
On 06/22/2017 11:45 PM, Even Rouault wrote:
>> I could potentially collect the API calls of projects I'm familiar with
>> (GDAL, shapelib, libgeotiff, mapserver and QGIS), so we have a better
>> picture of what is actually used in the wild. At the very least, it will
>> give us an idea of what the capabilities the new API should cover...
> Here's the result of my exploration of proj API use in those packages :
> All of them use only proj_api.h (quite logical since Frank Warmerdam was involved in all those
> projects at the time proj_api.h was introduced)
> So the projFileAPI isn't used (except pj_open_lib / pj_ctx_close as a legacy way)
The language bindings are likely to use projects.h, at least Geo::Proj4
(libgeo-proj4-perl) does. pyproj (python-pyproj) uses proj_api.h.
Using codesearch.debian.net shows that many of the PROJ.4 reverse
dependencies include projects.h, so getting rid of that requires
patching those projects.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
