[Proj] Coming releases of PROJ.4
Kristian Evers kreve at sdfe.dk
Fri Jun 23 02:53:14 PDT 2017
So still a rather short list I would say. Short enough that it is feasible to individually reach out to the affected projects.
I just had a look at pyproj. It includes a copy of the PROJ.4 source code as well, so we should not consider that project either.
The list at the moment is:
- ogdi-dfsg
- libgeo-proj4-perl
- gpx2shp
- pdl
- basemap
- thuban
- therion
- paraview
- SAGA
/Kristian
Fra: Even Rouault [mailto:even.rouault at spatialys.com]
Sendt: 23. juni 2017 11:37
Til: proj at lists.maptools.org
Cc: Kristian Evers
Emne: Re: [Proj] Coming releases of PROJ.4
> I did the following search:
> https://codesearch.debian.net/search?q=%23include+%3Cprojects.h%3E&perpkg=1
Looking also for #include "projects.h" brings more projects to your below list:
ogdi-dfsg, libgeo-proj4-perl, gpx2shp, pdl, python-pyproj
( I removed qtcreator, postbooks which have unrelated projects.h header. And gnudatalanguage for which the include is actually commented in favor of proj_api )
> It returns 7 relevant projects. Basemap, Mapserver, Python-pyproj, Thuban,
> Therion, Paraview and SAGA.
Consider mapserver out of this list. The only user is mapscript/php/php_proj.c and this file isn't is any CMakeList.txt. When adding it, compilation fails on many things, not related to projects.h itself
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170623/328966fa/attachment.html>
