[Proj] Coming releases of PROJ.4
caress caress at mbari.org
Mon Jun 26 06:17:41 PDT 2017
Thomas,
Thanks. Looking again at the discussion thread it should have been clear to me that the functions used by MB-System are not changing.
With respect to time dependence, we certainly are doing repeated seafloor surveys that resolve both lateral and vertical deformation. For instance, on Axial seamount our repeated 1-m-scale bathymetry surveys show ~10-m wide fissures that opened coincident with the 2011 and 2015 eruptions, and annual repeat surveys are measuring the several tens of cm of uplift each year associated with the inflation of the subsurface magma reservoir. However, I’m not sure how having time dependence in Proj can tie into our representing or modeling this deformation. Any advice would be welcome.
Cheers,
Dave
> On Jun 24, 2017, at 8:57 AM, Thomas Knudsen <knudsen.thomas at gmail.com> wrote:
> Dave,
> We are NOT changing the API of a core dependency of yours. We are adding a new, more coherent one, in anticipation of a growing need of fully dynamic datum transformations.
> The new API in proj.h is orthogonal to the classic API in proj_api.h
> I do, however, expect that you will need the functionality exposed in the new API - if not now, then in a few years time.
> /Thomas
> 2017-06-24 10:46 GMT+02:00 caress <caress at mbari.org>:
> As the architect of a package, I have similar feelings about anyone that changes the API of a core dependency.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
David W. Caress
Software Engineer
Monterey Bay Aquarium Research Institute
7700 Sandholdt Road
Moss Landing, CA 95039
caress at mbari.org
http://www.mbari.org/~caress/
Phone: 831-775-1775
