[Proj] Calculating +towgs84 values from source / dest .xyz file
Andre Joost andre+joost at nurfuerspam.de
Tue Sep 26 08:50:42 PDT 2017
Am 26.09.2017 um 16:08 schrieb Mark Johnson:
> At present, the helmert3d program bring this for:
> epsg:25833: 389918.0121759 5819698.8688798 34.790000000
> to
> epsg:3068: 23183.320000000 21047.418000000 34.790000000
I don't think the program is designed for trasnformations between
different projections. EPSG:25833 is transverse mercator, while
EPSG:3068 is Cassini-Soldner.
Helmert parameters are calculated on Earth-centered XYZ coordinates of
two different ellipsoids. See the sample test data at sourceforge.net
HTH,
André Joost
