[Proj] Converting between true north, grid north, and magnetic north
Chen Barnoy jicrbuh1 at gmail.com
Sun Feb 4 04:08:01 PST 2018
Thanks!
And is there a similar library to convert between grid\UTM north to true
north?
2018-01-30 23:59 GMT+02:00 Kurt Schwehr <schwehr at gmail.com>:
> Be aware that the magnetic field is time varying.  It can change pretty
> quickly near the magnetic poles.
> Yet another source... igrf.py
> https://earthref.org/PmagPy/cookbook/#x1-1190005.2.54
On Tue, Jan 30, 2018 at 7:03 AM, Charles Karney <charles.karney at sri.com>
wrote:
> GeographicLib https://geographiclib.sourceforge.io provides access to
> several magnetic models via the MagneticField utility.  E.g.,
>    echo 42.363 -71.006 | MagneticField -t now
>    -14.67 67.08 20228.0 19569.1 -5121.1 47840.0 51940.7
> The first number is the current magnetic declination at Boston Logan
> Airport using the wmm2015 magnetic model.
> The magnetic models need to be downloaded separately from the
> GeographicLib library using
>    geographiclib-get-magnetic
> On 01/30/18 06:42, Chen Barnoy wrote:
> > Hi,
> > Is there a way to convert between grid north, true north and magnetic
> > north in Proj4 or another library?
> > Cheers,
> > Chen
> > Proj mailing list
> > Proj at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180204/1a76ec65/attachment.html>
