[Proj] Proj-5.0.0 cct path to gridfiles
stevejking stevejking at talktalk.net
Mon Feb 19 13:49:46 PST 2018
Hi
When using cs2cs I don’t need to specify the path to gridfile (eg nadgrids
and geoidgrids).
But with the new cct I find I get “cct: Bad transformation arguments -
(failed to load datum shift file)” unless I give full path.
Using Windows 7 64 bit
Proj installed to
C:\proj-5.0.0RC3\proj-5.0.0
Grids present in nad sub folder
Grids Also copied in
C:\proj\nad
Regards
Steve
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
