[Proj] PROJ 5.0.0RC4
Mateusz Loskot mateusz at loskot.net
Wed Feb 21 14:21:24 PST 2018
On 21 February 2018 at 22:59, Kristian Evers <kreve at sdfe.dk> wrote:
> Have you set PROJ_LIB to point to a folder with the grids in the datumgrid package?
Initially, I did not set PROJ_LIB
Then I realised there is this comment in CMakeLists.txt
#TODO
# for data install testing the PROJ_LIB envVar
And, I set the env and re-run tests, no difference.
> The same test has been acting up before when a different grid was used, so I am not too worried about this one not passing.
OK
> The reason why appveyor isn't using VS2017 is probably because the configuration was set up before VS2017 was a thing. You are welcome to add it in a PR :-)
Sure, and I'm eager to add one, let's see how it goes :-)
https://github.com/OSGeo/proj.4/pull/810
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
