[Proj] Pipeline +init files, inverse
stevejking stevejking at talktalk.net
Thu Feb 22 14:02:19 PST 2018
Hi Kristian & Thomas,
I've tested reversing a pipeline, Using test coordinates -3 55 100, with
RC4, and the methods you've both described in this thread. On Windows 7.
Referencing Kristian's 3 cases:
case 1) do an inverse with cct
eg. cct -I +init=OSGBtrans:7709-3D
Works as expected, but is case sensitive, it must be capital -I as in
Thomas' reply.
-i generates error
Invalid option "i"
case 2) Init file Global +inv flag before the first + step
eg. <case2>    -t0 +proj=pipeline +inv +step ....
generates error
# Record 0 TRANSFORMATION ERROR: -3 55 100
 <invalid x or y>
case 3) Init file reverse entry that self-references the init file,
eg. <7709-3D_reverse>  +proj=pipeline +step +init=transforms:7709-3D +inv
generates error
cct: Bad transformationarguments - (malformed pipeline)
	'cct - h' for help
The init file and gridfiles can be found here:
https://1drv.ms/f/s!AvBQ7Pt73oO6iHV1WJ-n-lqLu_9r
Regards,
Steve
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
