[Proj] Pipeline +init files, inverse
Kristian Evers kreve at sdfe.dk
Thu Feb 22 14:11:13 PST 2018
Steve,
You have “-t0” in all the various transformation definitions in your init file.
“-t” is a parameter that you can use with cct, not a valid parameter in a proj-string.
Remove those and let us know how things go. Parameters with a + controls
The transformation setup, parameters with a - are specific to the command line
utilities in PROJ.
/Kristian
On 22 Feb 2018, at 23:02, stevejking <stevejking at talktalk.net<mailto:stevejking at talktalk.net>> wrote:
https://1drv.ms/f/s!AvBQ7Pt73oO6iHV1WJ-n-lqLu_9r
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180222/7e263fb2/attachment.html>
