[Proj] PROJ 5.0.0RC5
Jeff McKenna jmckenna at gatewaygeomatics.com
Sat Feb 24 15:29:41 PST 2018
Update: it seems many things were happening, causing me to look in wrong
places.  But in the end MapServer was in fact reprojecting the points;
what caused me total confusion was that I was testing with several
MapServer-related applications that are part of MS4W (Mapbender,
GeoMOOSE) and one application had a totally blank opening map image with
PROJ v5.  In fact for some reason the old hardcoded map extents
(displayed in EPSG:3857) no longer display the data (you have to now
zoom out a bit to see the data, reprojected with PROJ v5).  I'll contact
the GeoMOOSE team to let them dive into this (still, it could be my
Windows environment, as no one else seems to be testing MapServer + PROJ
v5 yet).
Very sorry for all this noise!
Short story: all is fine with RC5 here.
Thank you again Kristian for your passion driving this.
-jeff
On 2018-02-23 5:33 PM, Jeff McKenna wrote:
> Hi Kristian,
> No problems here on Windows in the MS4W environment, but I'm running
> into odd errors when I have MapServer call PROJ 5
> (https://lists.osgeo.org/pipermail/mapserver-dev/2018-February/015347.html).
>    Obviously an issue downstream not here, but I thought I'd at least
> mention it here that I am testing RC5 as well :)
> Thanks for pushing this release along.
> -jeff
> On 2018-02-23 3:19 PM, Kristian Evers wrote:
>> All,
>> I have prepared PROJ 5.0.0RC5. Downloads are here:
>> http://download.osgeo.org/proj/proj-5.0.0RC5.tar.gz (http://download.osgeo.org/proj/proj-5.0.0RC5.tar.gz.md5)
>> http://download.osgeo.org/proj/proj-5.0.0RC5.zip (http://download.osgeo.org/proj/proj-5.0.0RC5.zip.md5)
>> Since RC4 problems with vertical grid installation, the Horner
>> transformation and faulty polygon area calculation
>> in geodesic library has been fixed. Hopefully this will be the final
>> release candidate. I will call for a vote for
>> promotion to final release on the 27th. Unless serious issues are
>> discovered in the mean time.
>> /Kristian
