[Proj] PROJ 5.0.0RC6
Thomas Knudsen knudsen.thomas at gmail.com
Mon Feb 26 06:27:53 PST 2018
Hi Olli,
Thanks for testing RC6! What you have found is really more a matter of
missing documentation than a bug in the handling of +datum.
The thing is that the support for cs2cs style datum definitions are for use
in init-files only: It was introduced in order to be able to use the
current epsg-file with the new API. It will (presumably) be removed once we
have a streamlined way of producing pipeline style versions of EPSG data.
So the brief message is that except for init files, cs2cs style modifiers
are for use in cs2cs only.
The somewhat longer background story:
In cs2cs, the command line input is split at “+to” before handling the two
parts using two separate calls to pj_init(). From pj_init(), +datum is
expanded through a call to pj_datum_set(), which stomps on the parameter
list, adding the expansion from hardcoded values in pj_datums.c.
But the initial splitting of the command line at “+to” implies that a
+datum definition in the “from” part will not spill over to the “to” part,
while the opposite is true in your pipeline example, which actually expands
to:
proj=pipeline no_defs step proj=longlat datum=potsdam inv step
init=epsg:4258 ellps=bessel nadgrids=@BETA2007.gsb
And due to unfortunate (but hard to avoid - the full tale is complicated)
interference between old and new syntax, the expansion of +datum=potsdam
(i.e. the two tokens ellps=bessel nadgrids=@BETA2007.gsb) takes effect in
*both* steps of the pipeline, essentially meaning that what you do is this:
proj=pipeline step proj=latlong datum=potsdam inv step proj=latlong
datum=potsdam
i.e. a back-and-forth dance on the spot.
Why does this not happen in the first case (i.e. the one with two
init-calls)? It does not happen because inits in pipelines are *not*
expanded by pj_init() but by the pipeline setup code in PJ_pipeline.c (see
pj_init.c around line 540 for the ugly details), where each pipeline step
is handled in a separate pj_init() call, much like in the cs2cs case.
Finally, 4 take home points:
1)
Do not use cs2cs style modifiers anywhere else than in cs2cs and in init
files.
2)
Even in init files: Avoid them and write a pipeline instead.
3)
The +init=epsg:4258 step in your pipeline (which defines the output system
as ETRS89) is necessary in the declarative cs2cs style, but superfluous in
the cct imperative style, where you can get away with
cct -I +init=epsg:4314
or
cct +proj=hgridshift +grids=BETA2007.gsb
Note the missing “-I” in the last case: The grid shift file takes us FROM
the Potsdam datum TO ETRS89, while the epsg:4314 entry (in loose terms)
“defines” the Potsdam datum in terms of ETRS89.
Essentially it is a matter of sign conventions, which can give rise to much
confusion. So...
4)
Geodesy is often hard to grasp, but not always due to complex mathematical
and geophysical reasoning.
/Thomas
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180226/6801032d/attachment.html>
