[Proj] PROJ 5.0.0RC5
Thomas Knudsen knudsen.thomas at gmail.com
Wed Feb 28 22:58:22 PST 2018
Jeff,
That's interesting (although annoying!)
When I leave out the final nadgrids=@null, I get the correct result from
PROJ v5RC6. Can you reproduce that?
Note, I'm not implying that this should be considered a solution or
workaround, merely trying to narrow in on the
problem, which seems to be related to datum handling.
/Thomas
2018-03-01 0:38 GMT+01:00 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
> Update: I never heard back from anyone else about testing PROJ v5 +
> MapServer (and GDAL), so in fact I may be the only person to test this
> combination so far.  Because this is a PROJ mailing list I first give
> some more feedback with PROJ utilities, then later will list results
> from other software for anyone interested.  (in reality I first noticed
> the problem in MapServer but then each test in GDAL then PROJ failed as
> well, on Windows with PROJ 5.0.0-RC6)
> cs2cs
> I wanted to test PROJ v5 by using a point
> (487147.594520173,4934316.46263998) in EPSG:26915 (UTM Zone 15) and
> reprojecting that to EPSG:3857 (Google's Mercator).
> with PROJ 4.9.3
> cs2cs -v +proj=utm +zone=15 +datum=NAD83 +to +proj=merc +a=6378137
> +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
> +nadgrids=@null
> # ---- From Coordinate System ----
> #Universal Transverse Mercator (UTM)
> #       Cyl, Sph
> #       zone= south
> # +proj=utm +zone=15 +datum=NAD83 +ellps=GRS80 +towgs84=0,0,0
> # ---- To Coordinate System ----
> #Mercator
> #       Cyl, Sph&Ell
> #       lat_ts=
> # +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
> +y_0=0 +k=1.0
> # +units=m +nadgrids=@null
> 487147.594520173 4934316.46263998
> RESULT POINT: -10370728.80    5552839.74 -0.00
> with PROJ 5.0.0-RC6
> +nadgrids=@null
> #       Cyl, Sph
> #       zone= south
> #Mercator
> #       Cyl, Sph&Ell
> #       lat_ts=
> +y_0=0 +k=1.0
> RESULT POINT: -10370728.80    5522830.15 -10484.03
> Discussion
> PROJ 4.9.3 returns the correct value (I've confirmed this with many
> other tools including QGIS).  Can someone explain why those 2 results
> are different? (I have reproduced this problem on Windows and also
> Ubuntu 14.94)
> GDAL
> I wanted to test PROJ v5 by using that same test point (as a shapefile)
> in EPSG:26915 (UTM Zone 15) and reprojecting that to EPSG:3857 (Google's
> Mercator), using GDAL's ogr2ogr command.  (data used:
> https://www.gatewaygeomatics.com/dl/parcels-proj-v5-test.zip )  Below I
> have used the ogr2ogr command (included in the "commands.txt" file in
> that data download) and then ogrinfo on the reprojected file to output:
> with PROJ 4.9.3
> POINT (-10370728.7959208 5552839.74177463)
> with PROJ 5.0.0-RC6
> POINT (-10370728.7959208 5522830.1464459)
> Discussion
> PROJ 4.9.3 compiled into GDAL 2.2.3 returns the correct point value, but
> returns a different point value with PROJ 5.0.0-RC6
> MapServer
> Same problems as GDAL (reprojected layer has different extents with PROJ
> 5.0.0-RC6, causing problems to display the reprojected layer in a map
> image).
> If you made it this far in my long email, thanks for listening (I am
> totally stumped on this one, again ha).
> -jeff
> On 2018-02-25 3:45 PM, Kristian Evers wrote:
> > Thanks for testing, Jeff. It is very appreciated. I hope you sort of
> your problems,
> > PROJ-related or not.
> > /Kristian
> >> On 25 Feb 2018, at 00:29, Jeff McKenna <jmckenna at gatewaygeomatics.com>
> wrote:
> >> Update: it seems many things were happening, causing me to look in wrong
> >> places.  But in the end MapServer was in fact reprojecting the points;
> >> what caused me total confusion was that I was testing with several
> >> MapServer-related applications that are part of MS4W (Mapbender,
> >> GeoMOOSE) and one application had a totally blank opening map image with
> >> PROJ v5.  In fact for some reason the old hardcoded map extents
> >> (displayed in EPSG:3857) no longer display the data (you have to now
> >> zoom out a bit to see the data, reprojected with PROJ v5).  I'll contact
> >> the GeoMOOSE team to let them dive into this (still, it could be my
> >> Windows environment, as no one else seems to be testing MapServer + PROJ
> >> v5 yet).
> >> Very sorry for all this noise!
> >> Short story: all is fine with RC5 here.
> >> Thank you again Kristian for your passion driving this.
> >> -jeff
> >> On 2018-02-23 5:33 PM, Jeff McKenna wrote:
> >>> Hi Kristian,
> >>> No problems here on Windows in the MS4W environment, but I'm running
> >>> into odd errors when I have MapServer call PROJ 5
> >>> (https://lists.osgeo.org/pipermail/mapserver-dev/2018-
> February/015347.html).
> >>>    Obviously an issue downstream not here, but I thought I'd at least
> >>> mention it here that I am testing RC5 as well :)
> >>> Thanks for pushing this release along.
> >>> -jeff
> >>> On 2018-02-23 3:19 PM, Kristian Evers wrote:
> >>>> All,
> >>>> I have prepared PROJ 5.0.0RC5. Downloads are here:
> >>>> http://download.osgeo.org/proj/proj-5.0.0RC5.tar.gz (
> http://download.osgeo.org/proj/proj-5.0.0RC5.tar.gz.md5)
> >>>> http://download.osgeo.org/proj/proj-5.0.0RC5.zip (
> http://download.osgeo.org/proj/proj-5.0.0RC5.zip.md5)
> >>>> Since RC4 problems with vertical grid installation, the Horner
> >>>> transformation and faulty polygon area calculation
> >>>> in geodesic library has been fixed. Hopefully this will be the final
> >>>> release candidate. I will call for a vote for
> >>>> promotion to final release on the 27th. Unless serious issues are
> >>>> discovered in the mean time.
> >>>> /Kristian
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180301/c25c4390/attachment.html>
